Page 46-4 Figure 3 shows drilling the brake mount through the main gear leg axle and optimistically says 'insert a 3/8" drill bit through the assembly and final drill the smaller hole.' In my case, a 3/8" drill bit will not fit in the axle and it is very hard to try to use the drill bit to enlarge the hole through all that steel. The one hole in the U-1003 bracket is 3/8" already, as advertised.
What are others' experience here? Is it just too cold in the garage and things are smaller than they should be, or is the leg axle hole undersized? Should I blow-torch the gear leg?![Roll eyes :rolleyes: :rolleyes:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Doug.
Doug.
