jim miller
My RV3 has the plastic brake lines with the compression fittings. I have had
leak problems at the point where the line connects to the wheel cylinder. My
lines run thru some very nicely done fiberglass gear fairings. If I ever need
to replace the plastic line thru the fairing will it be possible? Is it common
to use other type of lines like aluminum and terminate in 303 hose for
example. Any advice appreciated. I have a new leak I just discovered
yesterday and haven't investigated the scource or exact problem yet.
Jim Miller
Jim Miller
