Hi all,
I fiddled with the brake lines in the cabin today.
I'm quite satisfied with the fit, only the flares are left to do.
As I'm building a 7A, the lines exit the fuselage near the gear weldments.
How I am supposed to do the flare at this place as the line has to go through the cover support ribs before the nut and sleeve can be installed? Do the cover support ribs have to be removed and the tubing inserted before doing the flare?
Thanks for your input.
