dick seiders
I am concerned about the tight squeeze between the four soft poly brake lines and the (2) K 1000-10 nut plates (on the upper firewall) in the vicinity of the adel clamp holding the lines to the panel deck. (see fig 2 ). I cannot determine what will be attached to these nutpklates, but AN3 bolts will be used further exacerbating the fit and introducing possibility of chafing the brake lines. Anyone else out there concerned about this? If so, what measures have you taken to protect brake lines?
Dick
Dick
