Question #1
I recently purchased an RV-6 and the brake lines are aluminum tubing. There is area close to the cowl on both sides that show signs of rubbing. When I replace this tubing, should I go back with aluminum? I split and wrapped some rubber tubing around the brake tubing to keep it from getting worse and also plan on opening up the area where it passes by the cowl. What are you guys using for the brake lines?
Also, inside the cabin, the brake lines are plastic tubing. I have not looked over everthing real close, but I figure these have a life extpectancy. How long do these typically last?
Question #2
The fuel lines from the firewall to the engine, are made of braided/rubber/firesleeved tubing. What is the life expectancy for this? The plane was finished in 2000 and only has about 200 hours on it. Should I be looking at replacing these lines due to age?
And #3.....thanks for such a great forum. Realistically, I probably would not have purchased an RV without this forum.
Thanks in advance.
Question #2
Thanks in advance.
