Charles in SC
I am at the point to hook the brake master cylinders up. What sealant should I use on the pipe thread where it goes into the Matco cylinder, also where the plastic fitting goes into the resivor? I called the Matco phone number that was on the side of the cylinder but it said the number was not in service any more. I am thinking Permatex #2. I did some searching here and some one suggested that as well. I have used it for a lot of things over the years and had good luck with it, but have never used it on a brake line.
Thanks in advance!
Thanks in advance!
