Barry_Barry
Member
Hi Gang:
I have aluminum brakes lines on my system. I have developed a STRANGE leak... Here is what is happening:
1 - Normal Brake Pressure -NO Leak
2 - High Pressure and HOLDING - NO Leak
3 - When I RELEASE the brakes after High Pressure - There is a small leak at the TOP of the AN Nut.
Question: Why is the leak showing up ONLY when the High Pressure is RELEASED?
In trying to repair this I:
1 - Removed the Aluminum tubing.
2 - Cleaned the Fittings.
3 - Inspected under a magnifying glass - Found small burrs.
4 - Cut off the Flair with the burrs.
5 - Installed New Ferule and Nut and Re-Flared the end.
6 - Tested as above and the leak was REDUCED but still a leak.
Any ideas?
AND!!! Why would it leak ONLY with High Pressure being RELEASED?... It does NOT leak with the high pressure applied... ONLY when RELEASED?
Barry
[email protected]
Any ideas?
Barry
[email protected]
