Taxing the RV10 back to the hanger recently I realized I had no right brake. Pedal went down with no resistance. Thankfully I was close to the hanger.
After getting the airplane into the hangar I intended to remove the wheel pant but it was too hot to even touch.
I got the pant off today and based on the black all around the bleeder valve I assumed that had failed so I replaced it. As I began to pump fluid back in I realized the leak is somewhere else. Before I start taking everything apart, I figured I post a picture here and see what advice I might get.
You can see in the picture from where the fluid is gathering and dripping. Anyone care to venture a guess what I'll need to do/replace to fix this?
![20190615_163105-e1560634451887.jpg](/proxy.php?image=https%3A%2F%2F520lw.files.wordpress.com%2F2019%2F06%2F20190615_163105-e1560634451887.jpg&hash=8c892c978bba90e64849fa932ec2783b)
