Jack Beck
Active Member
This winter we replaced the puck seals and bled the brake system. Everything worked fine while the weather was cold here in Wisconsin and the airplane rolls well out of the hangar. However after the last two flights, we felt the brakes dragging a bit when pushed it back in the hangar. We took off wheel pants to check the brake assembly and again put silicone on the pins. It looked normal and worked fine. This morning we pulled it out onto a sunny ramp and it again rolled without dragging. After about an hour in 80 degree heat just sitting without any brake application, pushing it back into the hangar resulted in some drag again. Anyone have an idea on what might be causing this?
