frankh
on wheelpant brackets...DOH!
Despite my best efforts it turns out this has been happening. Discovered it after 12 hours so no real damage done but obviously needs to be fixed.
I have been flexing the bracket away from the disc but of course when you put the nose cap on its impossible to know if the bracket is touching the disc.
I was thinking of cutting semi circular shim that extends thru the bottom of the wheelpant from 32 thou alu that I can slip between the bracket and disc, then fitting the nose cap and seeing if it goes tight after I replace the nose cap.
Is this about the best way or does anyone else have a more genius method?
Frank
Frank
