Cth6
Replacing the gear leg brake lines with braided ones from Tom at TS FlightLines after battling a leak due to flare cracks. Stock Cleveland set up with gear leg stiffeners installed. Did the stock length work for you or did you wish the lines were longer/shorter? Trying to figure out if they will fit before I take the plane down for maintenance. Thanks
