I'm having trouble fitting the lower rudder cap on my 9A. I've pretty much got the cut done,but when I put it on the rudder the front "fingers" that go over the rudder spar rub on the fuse sides near the end of it's travel.
The rod end bearings are adjusted per the plans, and I know I can deviate from those dimensions some, but it seems like the situation would be better with a lesser dimension rather than a greater dimension. This presents a problem then because it appears the rudder will interfere with the VS skin then.
Anyone else had a problem here or some ideas?
