Geico266
After 500 hours I need to replace the worn out baffel that transitions inlet air into the air box. It looks simple enough but I cannot find any info the plans Section 47. I tried to replace it once but it appears that after 500 hours the air filter box may have shifted an 1/8" or it was never centered to begin with. I did not build the plane.
Does anyone have good pictures of what the baffel should look like?
What sections is this covered in the plans?
Does the baffel transition from the outside of the inlet to the inside of the air box?
