Jeff R
Well, after previousoly bragging about how good I was at drilling out rivets, I really botched it this evening. I messed up a few rivets so, no problem, I will drill them out, I told myself. Only this time, twice, the drill slipped and now I have an extra hole next to two rivets. In getting the rivet pulled out, the holes broke through and now I have two, very elongated holes. This isn't something where I can drill out a larger hole and use the next bigger sized rivet, unless I want to use the kind of rivets they make ocean liners out of.
This occurred in the upper part of the rudder skins/stiffener, so the area isn't highly structural, to where I think I might be able to drill and rivet to either side of the botched rivet and simply fill in the botched hole later on. Either that, or buy a new skin and stiffeners, which I don't want to do.
Thoughts or suggestions?
Jeff
Jeff
