RVG8tor
I am very close to riveting on the boot cowl (forward top skin) I have had the skin off and on a couple times between initial fitting and dimpling. It seems starting at the top middle and working down to the sides and then working fore and aft makes the cleco process easier.
Should I use this same sequence to rivet on the skin? Just curious what has worked for other folks.
Any other suggestions for riveting on this skin would be appreciated. I already have identifed 4 locations for Cherry rivets, just can't get a bucking bar in there.
Cheers
Cheers
