bearcatr2800
Member
Any suggestions for a good quality boost pump for an IO370 ? Any imfo would be appreciated ! Thanks Bearcat4
Perfect! This is good to know.This has been figured out. The pump inlet fitting has an O-ring that floats inside the inlet manifold. This allows slight variations in the length if the tube we fabricate, plus the rest of the tolerance build up of the machined parts. The tube assembly is held to +/- .015?.
Don
