RV7AV8R
I noticed while on a long cross while in stable cruise if I turn on the boost pump the fuel flow went up about 0.5 gph. There was an initial surge in flow and then a stable higher rate. The fuel pressure goes up with the pump ON but I would think the float valve would keep the flow constant. Any one else notice this? Is it normal or do I have my float misadjusted?
