This has happened to me twice now. This type has a manifold on each end and the fuel can be drawn through the check valve in the flow direction and does not go through the manifold because the boost pump itself will not pass fuel in either direction unless the pump is running. If the boost pump is turned on it sucks the fuel from the intake side of the manifold and pumps it through to the other side manifold and up to the outlet. That pressure also tried to go back through the check valve to the tank but the check valve has a delrin ball that will sit on a conical seat, preventing the boost pump from pumping back to the tank and only to the outlet to the engine. The check valve is the smaller cylinder of the two in the picture.
This is the second time the check valve stuck and would not pass any fuel. Only the boost pump will get fuel to the engine. I took it all apart and all looks fine, cannot get it to stick
, works fine after disassembly and reassembly. Put it in the aircraft and it works fine.
Has anyone run into this before?
![Boost Pump Check Valve.jpg Boost Pump Check Valve.jpg](https://vansairforce.net/data/attachments/44/44139-ee1bfa41121eb43ed73afdeda08f02a7.jpg)
