Not obvious how these should be placed. Centered on the inlet, or shifted outboard?
Blain Well Known Member Sep 7, 2015 #1 Not obvious how these should be placed. Centered on the inlet, or shifted outboard?
bruceh Well Known Member Friend Sep 7, 2015 #2 On my RV-9A I centered them. You can always trim them a bit if they need it later with the baffling installed.
Blain Well Known Member Sep 8, 2015 #4 Perfect Best explanation I could ask for, Dan. Plus illustrations. Thanks.
AAflyer Well Known Member Sep 22, 2015 #5 Trim dimension? DanH said: Click to expand... Dan, could you please give an approx. dimension for where the trim line in your "Step 1" should be located, in relation to the inlet's leading edge? I working on baffles now, and this post is quite timely. Thanks, Bruce
