ppilotmike
Did you guys use your "close tolerance" bolts, nuts and washers when mating together the mid fuse and aft fuse, using the spacers?
If not, what did you use?
It seems to me, that once these pieces are together with the spacers in place, they will be together for a while, until the wings are permanently mounted. I want the best fit, so it would seem that the close tolerance bolts provides that, but then again, they are costly to replace them with new ones later, should they get scuffed or nicked...
