Since I hadn't finished the wiring and didn't want to close up the panels, I thought I would get on with some of the systems work. About 9 months ago, I put in the flap drive. Now I come to do the rear seat floor pans, I find that I can't get them in with the flap drive tubes in place No matter, undo a few bolts and I can get them out.
Now to the point of all this. The bolts holding the various components of the drive together (passing 90deg through the tubing) are corroded. Not seriously, but enough to cause me concern. OK, they've been through an English winter in an unheated garage but they will get much worse in real use.
The surface coating has gone and there are signs of rusting - just surface stuff on the shafts where they are exposed. The tubes themselves (primed inside) are fine, as are the bolts that went through the plastic bearing blocks. Obviously, I will put in new bolts but it's likely to happen again. Worse, some of the control system has a similar arrangement
Is this minor corrosion normal on bolts? Is there any way to prevent it? And am I going to have to take apart all my steel control fittings and check the bolts? On the other hand, none of these bolts takes much load, so am I worrying unnecessarily? These are components that wouldn't normally be taken apart so perhaps everybody's are like it - you just don't know it.......
