java
I'm thinking of some changes to facilitate the use of my Bogi bar. I like it, but on my tailwheel, one side has too little to grab (bolt head) and the other side is restricted by the cotter pin on the castle nut, so it only grabs part of the nut. The tow bar does not feel like it has a good grab on the tailwheel because of these issues.
I'd like to install a longer bolt, stack some washers under the head to give more extension to "grab" on that side, and use a nylock instead of castellated nut with a cotter pin so I can grab the nut side better too.
Anyone done this? What is the bolt I need?
