I know of a few that seem happy with it, but I can't say any of them were IFR airplanes.
I've talked to numerous IFR folks who have not been happy with the performance of the antenna and I've spoken with several more who have removed it completely and installed the whiskers after the fact.
I liked the idea at first, but I'm going the whisker route. I looked at Vic Syracuse's plane a few days ago and he's got whiskers mounted on the belly and directly below the Horizontal Stab to keep people from walking into it.
That's the route I'm headed down.
I have an Archer Nav antenna in my right wingtip, with careful attention to the instructions and wiring.
performance with an SL30 is excellent, and slightly outperforms the certified setup with dual GNS430s in the Cirrus I also fly a good bit.
I have intentionally looked for airframe shadowing with weak signals (distant VORs) and been unable to demonstrate it.
In both airplanes I tend to cruise higher than a lot of others (9-12K) and usually pick up VORs at 100+miles with enough signal for the SL30 to decode the identifier. Neither of the GN?S430s in the Cirrus does as well, but I suspect that is the antenna.
In a practical sense though, VOR navigation is like ADF was maybe 15 years ago, clearly a dying art. The only practical use for the VOR is flying ILS approaches and in that case you're so close to the navaid even a crappy antenna is OK.
If you set up an airplane for "IFR light" to avoid GPS subscriptions, you might fly an occasional VOR approach but the same thing applies.
I really wish they had killed off enroute VORs rather than LORAN
Now, with WAAS approaches, there is little practical advantage to ILS except as a backup that doesn't require expensive database updates.
I'd suggest that the Archer antenna will be more than adequate, especially if you take some care with the installation.
