I have to use a flush blind rivet on flaps skins because the nut plate installed on the ribs for the rod end bearing prevented me from shooting the regular rivet. Anyone know which blind flush rivet I can use in its place on the flap skins?
MK319-BS should work, you have to use a 7/64 drill bit to slightly enlarge the hole because they are in between a 3/32 and 1/8. Countersink the dimple a little to get the head to sit flush.
