Blank Circuit Breaker Panel Cover Plate
Bart
For the folks using a VPX or like system does anyone have a template or dimensions for the blank cover plate that needs to be created?
4 19/32” x 8 3/32”. 117 mm x 206 mm. As near as I can measure. :D
8 3/16 x 4 11/16, just another measuring point. You can order a blank fuse cover from Vans with the mounting holes pre-drilled if you don't want to make your own. That is what I did. I can't remember the part number though.
My dimensions came from the painted plate Stein sent with my panel. I used the Van’s plate that I had already painted, but it is on the airplane, so awkward to measure. The important dimensions are the screw hole spacings, anyway. :)
