Page 17-05, step 5...attaching the forward wing tip rib.
I had no problem fluting the rib to fit the curve of the skin, but when every hole is clecoed there is what at first looks like a sersies of holes along the outer edge, actually they are the round inner 'gap' between the 6 or so tabs that make up the front edge...will look like some sort of holes unless I can somehow change things...since the holes can all be clecoed to the upper skin there is not much that can be done it seems...I recall seeing the first RV12 demo at OSH and thought that looked rather poor....I suppose I can use micracle fill or somesuch filler prior to painting to close those holes up, but would like to somehow hide them while in the bare aluminum stage.
How did you wing tips come out?
