Better an 4 pipe exhaust.
Sanch627
Active Member
Vetterman 4 straight pipe exhaust.
Those who have used a Vetterman 4 pipe straight exhaust on the 4 , what cowling changes had to be made, I’m using a Lycoming O360 A1A..
None, if it hasn't been modified already
I must assume you are a "new build" rather than replacing an existing system. i have seen plenty of cowlings that had unique exhaust exit modifications added to them, and some very early RV-4 cowlings that had 2 formed tunnels for the outlet/tip clearance. The 4 pipe system fits a very narrow opening if installed correctly.
RV 4 with Vetterman 4 pipe
My 4 has standard Vans cowl and O-360 A1A and Vetterman 4 pipe. No mods necessary just install.
