I'm 5'4". Was thinking I'd build an RV-14a.
But then I started reading that it's great for tall people. Uh oh...
Will I be able to reach the rudder pedals?
Would another model be a better fit for me?
My 4'-11" wife is wanting booster cushions to see over the nose of the -10 a little better. That will make the rudder/brake pedal reach issue even worse than it is. She will require a removable false floor in front of the right seat so her feet will touch and take the weight off her thighs - and I estimate the cheater blocks on the rudder pedal crossbars will have to be fabricated from chunks of 6"x6" barn poles.
Fortunately the rudder pedals are only a concern if I'm going to teach her to fly or to get herself down with a disabled pilot. Rudder is optional, but no brakes = bad outcome.
speaking about all models, and specifically the -14, YES (friend of mine is 5'5" and just made his maiden a few weeks ago, no problem)Will I be able to reach the rudder pedals?
define "better fit"? Of course the -3, or the -4, or the -6, or the -7, (assuming lover's config is your wish) will better fit short (and lean...) bodies, than say the -8, -10, or -14...Would another model be a better fit for me?
I fly a -10, but I think the front cabin layout is similar.
I mounted the rudder pedals in the aft (closest to seat) position.
I have the standard Van’s seat. I fly with the seat one notch (I think 3/4”) aft of full forward. I’m 5’6”, so probably 1” longer legs, 1” higher eye-line. If you put the seat full forward you should be fine (the seat height goes up as it moves forward). At worst, a thin cushion behind you, but probably not. Just build the pedals in the aft position.
PS if you get a chance to sit in someone’s plane, be sure to ask the rudder pedal position as many or most are in the forward position. Not too hard to change, a few bolts, different link to rudder cable.
