KJBSouth
The eyebolts at the ends of Berringer master cylinders have 6mm holes through the bearings.
In contrast, Vans master cylinders have holes for AN3-7 and AN3-11 bolts. Does anyone has a source of equivalent 6mm bolts? I've searched the net and found 6mm bolts, but all are threaded all the way to the hex head. The bearings and washers should have unthreaded support.
Or, is there another solution that other Berringer users have found to work?
