Hi all,
Fitting the wheel pants, I see a number of you around here had to enlarge the tire wheel cutout on the bottom of the pants in order to fit the larger tires. Any guidance on how much more you widened and/or lengthened the cutout?
Also, in the updated Installation Guide (http://www.beringer-aero.com/en/file/brg_procedures/21/proc_fichier/van-s-install-maint-manual.pdf), there is reference to an RDL-008 spacer than are shorter than the usual U-408 spacers (since the AN4 bolt callouts are slightly different). Anyone know how much shorter these RDL-008 spacers are, so I can grind down the spacer I made to U-408 specs?
Thanks!
Thanks!
