I'm building an RV-8. I have Grove aerodynamic gear with the internal "gundrill' line for brake fluid. I also ordered the Beringer wheels, tires, brakes and axle kit from Aircraft Spruce (the one for an RV-8 with Grove gear).
When I test fitted the axle on to the Grove gear the brake caliper partially blocked the brake fluid exist hole at the base of the Grove gear.
Has anybody seen this before? Do I need a different axle?
