Some variations
Gents,
It appears that some haven't experienced interferences as I have. A friend with the same engine, prop and FI has marks on the inside of his cowl where the mixture arm/end of shaft is hitting. His cowl is not painted yet and he has about 800 hours on his RV7A. Very soon he will have his plane painted (so he tells me) and I am fairly certain that based on my experience he will see cracks in the paint on the opposite side of these marks.
There is no doubt in my mind that there is minimal clearance with this setup. Maybe it is the slight variation in engine mounts, shock mounts, prop weight etc that some haven't experienced this interference. As I mentioned in my previous posts the damage didn't occur immediately, it occured many hours since first flight.
I know that I have had some nasty shakey hot starts, but one bad hot start can ruin a nicely painted cowl if there is minimum clearance in this area.
My words of advice are if you going to paint your airplane prior to flying, don't paint your cowlings. After the engine is broken in and all the other areas of possible interferences are fixed (baffle clearances etc.) then paint the cowling. It might save you from repairing and repainting later.
