rmartingt
Started on fitting the slider frame yesterday, and after a good bit of head-scratching I finally realized why things didn't look quite right.
With the forward bow pulled up to the roll bar, the entire aft bow--pins, slide block, etc.--is shifted half an inch to the right. I know some have counseled not to mess with the square side rails but I don't see an alternative in this case; I think both of them as well as the center tube need to get tweaked.
Anyone run into this situation before? I'm going to be picking up a conduit bender from Lowe's aviation supply later today, but any further tips/suggestions would be quite welcome.
Thanks!
Thanks!
