JurgenRoeland
I started today bending the right elevator.
I followed the procedure, used a steel dowel about 4mm (0.1575 inch so even a bit more then 1/8 as prescribed) , the bending brake, lots of hinges.
I got the following results as in the images. Then trailing edge is really nice and evenly bend.
When inserting the side ribs, I am pleased about one side.
The other side, when installing the rib seems like the radius on the bend is too small. Any advice which way to go here?
- try to close the end of the rib more ?
or
- try to increase the radius of the bent on one side ?
The good one:
The other side:
or
The good one:
The other side:
