ChiefPilot
...consider a benchtop milling machine instead. I've used mine (purchased here: http://www.micromark.com/MICROLUX-BENCHTOP-MINI-MILLING-MACHINE-ALL-INCH-MINI-MILL,8102.html) for many, many tasks over the life of my -6A project and have done a number of other projects with it as well. Some of the RV tasks I've done with it include :
- Cutting the instrument panel, including round, rectangular, and polygonal holes
- Cutting the horizontal stabilizer shims to account for a slight fuselage twist: one shim is 0.125", the other shim is 0.110". The stab is perfectly level.
- Using a fly cutter for many different lighting holes, running it at under 100 RPM. The spindle speed is completely variable between 0 and 2500 RPM, and running the fly cutter at a low speed is less "sporty" than the 600 RPM minimum speed found on many low-end drill presses.
- Cutting various brackets from aluminum bar and angle stock much more precisely than could be done using a band saw and/or die grinder. The support brackets for the electric flap motor, the fuel tank support brackets, and many others.
- Cutting multiple aluminum tubing spacers to the same exact lengths. Making standoffs is trivial.
- Drilling & threading holes exactly in the center of aluminum rod (a lathe might be even better, but I digress).
- Split UMHW blocks precisely - no washer spacers needed
- Drilled holes in hardened steel without issue - at a slow speed (perhaps 200 RPM), the drill doesn't overheat and workharden the piece/dull the bit.
