DavePlaneGrips
B&C is closed so I'm hoping folks here might know. The BC462-H instructions talk about mounting the alt to the vacuum accessory pad with studs, and they give you either UNF or UNC nuts to accomplish this. Unfortunately my vac pad blocking plate seems to be attached with screws, not studs. Is it okay to use screws, torqued to the proper spec for what I'm guessing is 5/16-18 hardware (I haven't checked yet if the stud torque is different than the screw torque)?
Also, is it possible to mount this to one of the other unused accessory pads below? I recall the left one is for a mechanical fuel pump, I don't know what the right one is for but it has studs. Are the drive ratios even the same as the vac pad? Will it even fit?
Ignore red circle from previous post.
