Has anyone converted their -6 to the Bat-wing tips? And if so, did you see any difference in flight characteristics?
Not concerned with top end. Did the extra area make a difference in stall speed or low speed roll control.
Mel,
Adding the Batmobile tips will add span and area. This will definitely help the low end, if that's what you want. As you know, induced drag increases with reduced airspeed (or more specifically, higher AOA). And induced drag is tightly tied to aspect ratio - increasing AR will drive the induced drag numbers down, especially when slow. Adding AR and span will also shift the best L/D speed downward, if that's what you want.
Mel, don't you have a biplane you should be finishing?
My guess would be #2. Vortex generation is usually greatest at lower speeds and higher AOA, not at cruise.Two possibilities come to mind: 1) Its what you said. There's some vortex wrapping around the tip, and impinging on the upper surface. or.... 2) the larger overall surface area of the tip puts more load on it. The bat tips' planform gets wider toward the trailing edge of the wing, so there's more chance for loads to build on that part of the structure. Those lift loads then can bend the entire tip upward just a bit, resulting in the upper surface sagging.
......when I lift the tip as much as I dare. I'll tuft test soon and reply....good idea, one I've always wanted to try. BTW, the tips are 17" wide next to the aileron leading edge/rear end of the top skin and very limber with no internal reinforcement. Does Van recommend foam/glass or other stiffeners for these tips?
Regards,
