Van's specifies the 25RG-XC Concorde battery in OP-37 drawing. That's what I used, and it fits the stock battery tray and works well for me. I purchased mine from Aircraft Spruce https://www.aircraftspruce.com/catalog/elpages/rg_25xc.phpWhich battery make, model best fits the RV10 battery tray? Thanks
Not much trouble to modify the tray to accommodate batteries half the cost of batteries for Certified aircraftVan's specifies the 25RG-XC Concorde battery in OP-37 drawing. That's what I used, and it fits the stock battery tray and works well for me. I purchased mine from Aircraft Spruce https://www.aircraftspruce.com/catalog/elpages/rg_25xc.php
Regards
Wow…And away we go with the Bomb under the hood debate again.
My Odyssey PC 680 started my AEIO 360 with 10:1 pistons every time without breaking a sweat. Under any condition.
I would remove and replace them every 4 years and use the removed one in other non- aviation applications for another 10 years or so.
A PC 950 did the same for my high compression IO540.
I never had a need to remove these long lasting capable batteries and replace them with a toxic fume producing a potential lithium bomb. Especially in a hot engine compartment!
That would be fixing a problem that I didn't have with a dangerous solution.
Educate yourself on the dangers of lithium batteries before bolting one to your firewall.
Please!
Informed? So you watch somebody INTENTIONALLY "torture" a LiFe battery to failure and then state that it is a "lithium bomb"?I don’t charge my phone while airborne or some other dumb things
Im not terrified, just cautious and informed
You do know that you're carrying hundreds of pounds of avgas that is highly explosive, right? better keep the tanks dry and admire it in the hangar rather than fly it...!I don’t charge my phone while airborne or some other dumb things
EarthX is the standard battery in the new Cirrus. Banned from the skies?! Far from it. You spread fear, uncertainty, and doubt due to lack of knowledge on the subject. Anyone is free to make their own choices for risk mitigation but the inherent risks of an earthx lithium iron phosphate battery are certainly safe enough for the certified world at this point…The goal is risk mitigation, not elimination.
The scrutiny on lithium batteries has resulted in a prohibition on shipping them air freight or in checked baggage.
When those restrictions are removed, you can use that argument.
Once again there is no need for potentially deadly batteries on an aircraft when there are safer alternatives that work very well.
Instead of throwing around anecdotes and/or forming opinions based upon same, do some quality research. At a minimum, look at the actual regulations as they pertain to transportation of "Lithium". Here ya go:The goal is risk mitigation, not elimination.
I suspect the goal of Cirrus (and most aircraft manufacturers) is to lower empty weight.EarthX is the standard battery in the new Cirrus. Banned from the skies?! Far from it. You spread fear, uncertainty, and doubt due to lack of knowledge on the subject. Anyone is free to make their own choices for risk mitigation but the inherent risks of an earthx lithium iron phosphate battery are certainly safe enough for the certified world at this point…
Link for reference: EarthX Cirrus
I suspect you are correct. But that comes with a host of other benefits as well. Some drawbacks? Perhaps, but not enough to bar it from certification.I suspect the goal of Cirrus (and most aircraft manufacturers) is to lower empty weight.
I wish that thing would fit in my battery box!I like made in USA, these Deka AGM batteries are the best you can get https://www.amazon.com/Deka-Power-Sports-ETX20L-Battery/dp/B0026H3CB4
Weight is one of many benefits. But in the same or smaller form factor you can get a significantly higher capacity battery.I suspect the goal of Cirrus (and most aircraft manufacturers) is to lower empty weight.
