caution; side mount ISSUE
I should mention that after side mounting my 925 in the engine compartment, the heat caused the lid to curl, and this allows the tiny vent 'burp' caps to fall off! No harm was done, as the fluid is suspended in the mat they say, but you may want to have some kind of retainer just to ensure under all conditions...the lid STAYS ON!
Also had a Concorde in the plane, flown only 10 -15 hrs a year, seemed to still crank ok after 6 years, but the voltage was gradually dropping, so swapped for the Odyssey.
