ScottCC
Member
I'm at the point of running wiring from the aft fuselage to firewall (RV10) and am trying to decide what size battery cable to use. Is AWG 02 good or is 01 better? What amp rating should I be looking for?
Also I'd like to use firewall pass thru connectors.
I'd like to use a pass thru connector that can be insulated but having trouble finding one. Source suggestions?
Thank you!
Scott
Thank you!
Scott
