Saville
Hi all,
I just joined this forum a few minutes ago although I've been reading it for weeks.
It's time to get my own airplane, and I'm trying to decide between an RV3, RV-4 and RV-8. Each have their own pluses and minuses, as you all know.
I go around and around with all the considerations, and I'll put those in a main forum post.
But focusing on the -3, my reading has turned up several questions. I was hoping someone could answer them.
1) C/S Props
I would like to hang a Constant Speed prop on a -3.
Through reading and watching Youtubes, I indirectly inferred that hanging a C/S prop on a -3 is problematical. It seems to have to do with the Weight & Balance. I watched a video by Paul Dye, and he mentions he wanted a C/S prop but had to find a lightweight one. So he hung a carbon fiber 3 bladed prop on his -3.
That sounds expensive. Is the number of C/S props, that are light enough for a -3, limited such that I have to pay huge dollars for a carbon fiber 3 bladed prop?
2) The Wing
I've read a lot about the failures an limitations of the first version of the wing. I've read about the two upgrades to existing wings. I also know that I can buy a QB wing kit for the -3. My questions are:
1) How difficult is it to retrofit a new QB wing to an already-built RV-3? Could it be impossible if tolerances were not strictly kept?
2) The new QB wing has wing tanks. If I want to plumb those tanks in and use them, and NOT use the fuse tank, will that increase my Useful Load?
- If I'm not mistaken, the fuel in wing tanks are not counted against useful load in the other RV's (though I don't really understand why)
3) How hard is it to remove the fuse tank and plumbing if I want to use the Wing tanks only? Would removing that tank pose difficult W&B issues?
Any insight would be helpful.
Thanks!
1) C/S Props
2) The Wing
Thanks!
