basic dimensions
Scott Will
Does anyone have the following dimensions available for the -10?
- horizontal stabilizer length
- tailcone length (from the emp. kit)
- fuselage length (firewall to aft bulkhead)
- wing length and chord (with or without controls)
Thanks much in advance!
These should be pretty close:
tailcone length: 107.5"
cabin firewall to baggage bulkhead: 115.5"
H Stab: 133.5" without tips installed
Another critical piece of info is that the tailcone width is around 38" (won't fit through a standard door).
Bob #40105
Thank you! So to get a fuse length I add 107.5 + 115.5 = 223" firewall to aft bulkhead? (18.53 ft) My workshop happens to be 19.3 ft long on the inside so that's kinda good to know.
I have a 60" door so that part is cool... but thanks for the heads up on that!!
Scott,
Total length from firewall to aft edge of the tailcone with the tailcone joined to the cabin is actually about 214". There is a triangular piece on the tailcone that sticks out and overlaps below the baggage door which makes up most of the difference.
You also asked about the wings - mine are at the hangar but my recollection is that they are each about 12'8" (or so) without the tips installed. Total chord with flaps/ailerons is 56".
Bob
More measurements requested
Speaking of measurements, I was looking at a T-hangar and wondered what is the length from the trailed edges of the wings to the front of the spinner, and from the trailing edge to the back edge of the VS (or whatever is the point the furthest to the rear)?
Bill Greenley
starting a 10 real soon
