Paul Eastham
With the onset of winter temps (all of 40 degrees in california
) I noticed my throttle control was feeling a bit less smooth. Then one cold morning it was hard to move at all. It did loosen up after a few strokes...I figured it was the control cable giving up on me, as many others on this forum have encountered, and ordered a new one.
Once I had the new part in hand, I disconnected the cable, and found that it was actually the carb itself that was causing the stiffness. Hmm, lubrication? I sprayed two tiny squirts of LPS-2 on either side of the carb's throttle shaft (the shaft that connects to the control horn), and it is moving smoothly again.
Reassembled and everything feels as good as new.
Never heard of anyone else having to do this...Cause for concern, or normal?
