Baggage vs. weight and balance.
My RV-9A came out about 100 pounds over weight compared to Van's prototypes. Constant speed prop, stereo CD/Tape player, yada, yada, yada. The end result, When I took off for OSH last year, I had me (240 pounds) and my computer and a box of charts in the front seat beside me. The baggage area had tent, air mattress, chair, clothes, etc. The net was 138 pounds of stuff back there and no CG problems when I did the weight and balance with that load. It flew very well, except that I was right up near my gross weight on a hot day with full fuel when I left Chattanooga on July 24, 2005 headed for Oshkosh. [
http://www.n2prise.org/rv9a151.htm ] That was the longest takeoff roll I made up to that point in my flights -- 500 feet instead of 300 feet.
You guys are on the right track. Do the numbers and go for it. By the way, I was able to demonstrate to the AB-DAR that the weight and balance works up to 2000 pounds gross weight. I also posted two sets of V-speeds on the panel and in my POH. One set at Van's recommended gross weight, and a second set of V-speeds for the 2000 pound max gross weight limit.
Just for the record, my weight and balance is fine with two 250 pounders in the seats, full fuel (or minimum fuel), and 100 pounds of stuff behind the seats.
Jerry K. Thorne
RV-9A slider N2PZ
172.7 hours on the Hobbs
www.n2prise.org
