Steve Emmett
Member
I'm at the point in the plans where it calls for installing the baggage floor. Is there any reason to delay this step?
I just finished this area, and made some floor access hatches for strobe power supply in one and spare parts, etc. in the other. They also allow me to pull wire if needed, but after looking at the center tunnel, it won't be hard to run everything there and use Adel type clamps to keep everything clear of the pushrod.
In my six, I ran some of that flexible ribbed conduit through both baggage sides, and then riveted them closed.
L.Adamson --- RV6A
Larry,
Where did you end the conduit going forward? Did you run any wires thru the spar or bring them around the sides and over the spar? Thanks,
