Baggage Floor Closeup
rockitdoc
Sponsor
So, I am ready to close in the baggage floor on my -14A, but there is a hole in the belly skin that looks like it will be getting something inserted in the future and I'm wondering why not attach whatever it is now, before the baggage floor is on and kinda in the way.
The red box shows what I'm talking about.
  • Baggage Floor Showing hole.pdf
That is an antenna mount location. Leave it out now as you will most likely have the fuselage resting on something.
Easy to put in later.
Carl
I put my transponder / ADSB antenna here. It is easy to reach in through the tunnel later to tighten the two nuts and attach the coax. Put the antenna on after the plane is on the gear to avoid damage to the antenna.
