Split the difference
I split the difference between the two methods and placed 8 strategically located -3 cherry pop rivets and put clecos in evey other hole. They pull the dimpled skins together pretty darn tight. After using the strap, glue, and soft rivet method, I then drilled out said rivets.
Like Paul, I can't say if it is a better route or not. But my door fits very well.
