CharlieWaffles
Is anyone using a door sensor to show if the baggage door is open on an EFIS or Annunciator panel? If so, what kind of switch are you using?
When I was a college line boy, we had a Cherokee with a family forget to latch their baggage door.When they took off and turned out, all their luggage fell into a shopping center parking lot.
I'm going to be using an automotive-style sealed microswitch. I agree with Bob that it should be a non-issue but it's easy to install now so why not?
Because it adds weight. Light airplanes perform better than heavy ones and can carry more payload.
Dave
...you can't remove the key without locking the door!...
Sweet... where'd you get the lock that does this?
I was thinking about this a little bit last night.
If you do decide use a switch for the door, I'd be sure to buy one with a strong enough spring to open the door if it's unlocked. Otherwise an unlocked door that is pushed closed (or blown closed by prop blast) could give you a locked indication when it really isn't.
