I basically did what Larry ^^^ is suggesting, I put some 3/4" angles as reinforcement on the top baggage rib flanges out in the four corners & fitted #10 nutplates. I used the two-piece tie downs Vans have in their shop, so the base is permanent on the floor and I can put in the spring-retained rings as/when needed. I might even have a photo I can share somewhere.....
