PlaneBuilderBill
To one and all...I've built and re-built several baffles and this one really has me....well, baffled!
Engine: 0-360 A-1-A w/ the standard Dynafocal mount. I set up the cowl per Van's instructions with approximately a 1/8" down offset just behind the top of the spinner to allow for the engine drooping. With this setup, the baffle sides (especially the two adjacent to the #1 & #2 cylinders) have only about 3/8" to 1/2" of metal (This is measured from the valve cover gasket to the top edge of the sheet metal). As the baffle side is mounted to the flat surface of the cylinder, there is virtually no room to attach the fabric seal material! And, this is barely giving me a finger's width of space to the inside of the top cowl.
I've spoken to Andy Duff and he said this is the way his is too (he has actually padded the inside of his cowl in a couple of places to keep the shaking engine from banging into the cowl (metal to fiberglass)...Am I just too concerned or is something sounding fishy???
Thanks in advance, any advice would be appreciated.
